Looking for someone to de-smog the FJ60. . . (1 Viewer)
sschruff
Make PSILOCYBIN legal for TBI/PTSD/TRA&D
NOLA
Looking to desmog the FJ60 and would like to see if there's anyone local who knows what they're doing?
Thanks-
Shane
not a hard job
soak the AIR tube fittings on the head a few day first .remove tube & adapters in the head use an pipe plug to close the holes think 1/8" might be 1/4"
remove all the bs hoses can fold or crimp all the tubes on air cleaner can find a cap to fit the large lines remove smog pump gut it install new bearings good to go .will need it to adjust belt
remove EGR cooler plug lines the valve & relays on the driver fender well leave blower it cools carb
plug vac ports not used on carb
that should be about it
Looks like you found your man!
