Looking for size of copper washer
So. Cal
I searched, but I could only find the part number for the flat copper washer that are used on the fuel lines for the fuel filter on a 1FZ-FE engine. I don't have a new filter yet, but I'd like to have some extras on hand.
I have about 20 of the fuel filters in stock. I can measure for you in the morning. I’d be curious if they weren’t the same size as the brake banjo bolt washers 🤔
Thanks man....I've read that some have lost some washers as they're installing them because of the cramped spot the filter resides in and that's why I wants some extras.
In case it helps...
Damn Joey, I wish I lived closer to you. I'd love to listen over some beers to everything you know about cruisers.
I just changed my fuel filter earlier today. I thought I lost one of the washers, but luckily it had fallen up my sleeve while I was up under the truck. It’s easy to lose them for sure. Good job planning ahead, I didn’t. 😆
So, are the washers that come with an OE fuel filter made of Aluminum? I know you have it listed that way, but I've heard some are copper and am wondering if the type of metal used matters with the application here. 🤔
The washers on mine were aluminum.
I’d guess as long as it crushes to seal, and dosnt react with whatever it’s sealing in, either would work.
I'd venture a guess that it depends on the year. I have seen copper fuel washers on LCs before but every 1FZ I've touched has been aluminum.
