Looking for New tires
So I can get a pretty good deal on BF Goodrich all terrain ko2 32x11.5x15 with the 19mm offset rims I should be able to get away with little or no frame rub? What is the equivalent in metric though? The sizing confuses me slightly. Want a 32 metric equivalent in a 15 inch rim. Cheers!
Just download the tire spec sheet from the manufacturer. It lists all the specs for metric/imperial side by side so it's easy to compare. https://www.bfgoodrichtires.com/upload/bfgoodrich/specifications/specs-all-terrain-t-a-ko2.pdf They usually give circumference, diameter, number of plies, ideal rim width etc.. You can also use a website like this to compare tires also: Tire Size Calculator
