Looking for a shop in tucson
Tucson Az
I was gonig to Bill from Bill's toy shop but he took off to CO. I need to find someone who can get this lower check valve off.. I called Nippon but, they were not to confident they could get it off or sure what exactly what I was talking about. Or if there is anyone who has done this with out removing the exaust manifold I sure could use the help.
Thanks For the help
Brian
The first pick is the check valve the second is what you have to go through to get to it. If you have a 60 just look under the brake booster close to the firewall.I was told by a very wise man that I would have to remove the manifold to get it out he got that from the Toyota manual. I can reach it from under the truck and through the top put I can't get it to move at all. I found someone who did remove it the same way i'm tring to get it out so it has been done. I soaked it with liquid wrench and wrenched it all day with no luck. I realy would hate to drag any one else in on this because for one I spent all day and i'm sure as soon as someone else touches it might pop off and two it sucked. I will gladly fork up some fresh growlers of Gental Bens IPA for any help.
Thanks Brian
Anyone got I number for Tim Hill out in Marana and If he still works on 60's? I havn't been out there in a long while if that is still were he still is. I used to see him at Kurts every now and then.
Thanks Brian
I was out there today, not many 60's on his place anymore,(some body panels) but he might be able to help you out.
Home:
520-616-0304
