Wanted looking for A/C parts for 3B -
S.CA - N.OC - Fullerton
anyone got stock parts, custom parts or CAD drawings for a 3B air conditioning setup
I have all the stuff in the dash (from fj60)
I need everything under the hood but the critical stuff is the bracket, pulley and 12v amplifier.
I'm currently in the Vancouver BC area... thanx
Search in the 70s section. there was a fella (cant recall his handle. maybe hobie?) who made an itemized list of everything needed to put in AC into a 70 with a 3b. IIRC, it totaled 3k in 2007. This should help you with what you need.
I've got ex BJ74 AC Compressor, hoses, Compressor bracket, Tensioner bracket/pulley.
Have 6 series AC condensor also. Amp is 24v so that won't help you.
1 hour east of vancouver.
is the typical 60 compressor the same as a 70 (same bracket)? do you have the crank pulley as well? would the hoses, etc. work on a 60? thanks
Generally compressors (and brackets) are specific to engine series, not body series.
Most pre 1990 Landcruisers use 10P-15C compressor bodies, but there are variations in the segments that are stacked together to create the compressor body, which result in Engine series specific Compressor bodies. The rotors also differ between B, H, F series. Most compressors end up with the same 4 bolt mounting pattern but the rotor and segment dimensions put the belt pulley in the wrong place to line up with the Crank pulley and tensioner pulley.
So the answer to your question is Yes, and No.
Compressor and bracket/tensioner etc will be same between a BJ60 and BJ70, but not the same between an FJ/HJ60 and a BJ70
Clutch stators are fairly interchangeable between models.
Clear as mud?
I don't have the 13B-T AC pulley for the crank but I may have a certain 12H-T pulley which can be redrilled to work, or you can order new from US toyota dealer.. last time I checked they were still available.
I probably have some HJ61 AC hoses which should work to connect B series compressor to 60 series Condensor.
I probably have some HJ61 AC hoses which should work to connect B series compressor to 60 series Condensor.[/QUOTE]
Yea, clear. The pulley is $80 from https://www.1sttoyotaparts.com/oempartscat.html. So to clarify, I would be interested in :
1) compressor bracket
2) working or core compressor
3) idler pulley bracket/pulley
4) condenser
5) workable hoses
6) HJ61 crank pulley if it's cheap
besides the amplifier can you think of anything else I would need from the engine bay - the dash stuff is all in there. Thanks..... Wana shoot me a PM on a package price for the stuff you have? I may be able to make it out there next week. Also let me know if you have any reason to head south... maybe we can meet somewhere. Thanks.
I have a used 12v ac amplifier out of an HJ70 troopie. Its a little black box, part number ND 077300-0660. Its up for sale if anybody's interested!
