I haven't wheeled w/ my aussie locker yet. Pulled some stumps out of the back yard today, though. The rear end drifted around w/ both tires spinning, not just the usual one diving into the dirt.
I put synthetic in there after my gears were broken in. Quieted down a little. I kinda like roaching my 33's around corners. Otherwise, I just hear "click, click, click".
I'm still getting used to the backlash of the locker. My clutch is chattery, due to a rear main leak. This was frustrating as hell when trying to learn the behavior of the locker, and be really soft on the new gears, while my clutch is shuddering away from every light. s***.
The c-clip thing was a trip. Had to get the truck towed back to the house with 90wt spilling out of the axle. I freaked out when I saw the splines at the diff end of the axle. I thought they were mangled from bouncing off the pavement when it liberated itself from the truck. Turns out, it was metal scooped out from the inside of the axle tube, crammed into the splines. I picked out every bit, and cleaned up the splines w/ a file. Damn, those axles are tough!
I also now have a wee bit of a flat spot on the bottom of the drum backing plate. I pretty much cut off the slag, hammered back into shape, and test fit the drum to clear. Not much of a issue, until I get in the sand or mud.
Let this be a lesson...Triple check the c-clip!
Happy trails...
