location of wiper and dimmer relay on LJ73 LHD?
N.B., Canada (east coast)
hey guys, fixing up an 88' german LJ. Wipers and lights not operating at all. Anyone know right off the location of the relays? Would save me some time while I do a little body work.
--thnx for any help. they're 12v so shouldn't be as hard to find replacements...
I had a similar issue with my HJ75 when I first bought it. When you selected "bright" lights the lights would occasionally go out all together. When you returned to the "dim" position the lights would once again come on. The issue was corrosion in the turn signal / headlight stem. Once it was replaced the issue went away.
Hope that helps.....
hi, thnx for the response. i actually plugged in a light/signal switch from an HZJ75 that I had here. made no difference. not even the blue hi-beam dash light came on with either switch. I tested the bulbs and they're good. the good news is i think the dimmer relay is the same 12v unit found in 4runners.
I'll tear into the underbelly tomorrow night and see if i can track it down...
Sorry my suggestion didn't work out. Hopefully someone a lot smarter than me will chime in.
The wiper relay is located on the passenger side pillar behind the plastic side cover right next to the blower fan. The light dim relay is located under the steering column unit along with 5 other relays. You will hear it ticking when you switch between hi and low beam. Go to www.toydiy.com ,select you car , relays and you should see where every relay is located at.
hope this help
