Local Metal Fabricator - Triangle Area
Oriental, NC
http://taubenreuther.de/einbauanleitung/16-5850_DE.pdf
I need someone to help build a hidden winch system for 100 series. Similiar to the pdf attached. I like the way they did the cradle for the winch to sit on.
Does anyone have a person that could bend/weld a piece a metal for me similiar to the pdf?
Thanks,
uzj100
I would post this up on NC4x4.com you will find a variety of guys willing to help out on this.
Personally, if I keep the 80, what I am planning on doing is buying a "Jeep winch mount" at Harbor Freight for $50ish.
Then modding it as needed to fit under the front bumper. My goal would be for the front mounting surface to meet the bumper/cover itself.
The reason for that is instead of cutting the large hole, I would cut a very small hole for the cable to go thru and then bolt the roller fairlead to the outside of the front bumper (thru it / into the winch mount) so the only thing showing is the fairlead / no big hole.
The other thing I would do is mount it upside down so that you can reach under the bumper to turn the engage/disengage lever easily.
But the item you are showing is not "that hard" to build / you should be able to find a local to do it. NC4x4 is full of guys with their own shops, etc.
Sam
