Hi All,
The purpose of this post is to share my experience with disassembling the rear differential and to seek help with problems I encounter along the way.
I was wondering if I could have some advice. I own a 1991 LJ78 Prado, 150,000 kms, and have 2 main problems:
1) I noticed the rear diff is leaking oil where the propeller shaft meets the differential carrier (pinion oil seal?) and also around where the differential carrier meets the axle housing (differential carrier gasket?). THe leaking is significant requiring I top up the gear oil once every couple days and leaves an oil puddle on the ground when the truck sits. Im thinking I need to replace the pinion seal.
2) The rear diff oil plug screw magnet had metal shavings, about half an inch of gunk with a couple of half inch square shavings. Note this was the first time I ever removed the oil plug and cleaned it so Im a bit on the fence about whether I have a thrown bearing problem. I also noticed the truck developed a whine sound around 90km/hr which seems to be coming from the rear drive train. Its not loud or squealing, I just noticed it because it wasnt there before. I know the fluids have been good. I decided since I am going to change out the rear diffirential carrier gasket I may as well inspect the bearings.
I have decided to embark on replacing the pinion seal and the differential carrier gasket.
_______
Pinoin seal replacent:
1) I removed the rear propeller shaft
2) Removed the staked part of the the nut then realized I needed a 30mm socket to remove that nut to get the companion flange off. I dont own one so Ill have to wait till tomorrow to get one in order to keep going.
Onto Differential carrier gasket removal:
1) In the FSM for Removal of Rear differential it says.
a) Remove drain plug and differential oil
b) Remove rear axle shafts: Semi-floating type see page SA-108, Full floating type see SA-116. Im not sure whether mine is full floating or semi floating. Looking at the instructions for the semi-floating type. It looks like with this model you have to access the differential first to remove clips which hold the axles in place at the differential before you can remove the axle shafts. The pictures shows differential cover that can be unbolted. My Prado doesnt have a bolted on cover, its welded on tight (see pic)
The instructions for the full floating say just to remove the tire, drum, and pull the axles out with no need to access the differential which seems easy enough.
Main questions:
1) Is my truck full-floating or semi-floating?
2)While waiting to get the 30mm socket, I removed all the screws to the differential carrier housing and tried to pull it off so I can look at the gasket. I hammered the differential carrier (housing) with a drift and it still wont come off. Do I have to remove the axles before I can get the differential carrier (housing) off?
Thanks !
Lee
_______
Main questions:
Thanks !
Lee
