LJ78 Door Control Relay Location
South-Africa
Hello Everyone,
I am trying to debug my cruiser's central locking, I checked every door all of them have the electronic locks but when I press the unlock button only the drivers side locks and unlocks. Does any of you guys/gals have an idea where the door control relay is located in this cruiser? Any help would be appreciated.
Thank you for the response! I have that exact pdf! But the picture with it in is really silly. Shows it being in the left rear window/right side door?? Not sure. I can check behind the rear left side interior panel, just wanted to check if anyone know the exact location so I don't waste time removing panels unnecessarily. 😅
The controller you are looking for is in the drivers door. I’ve had to replace this controller before.
Thank you very much sir! Now I can start troubleshooting why the central locking is not working on my other doors, I pray that that relay is not missing or something. Cause only the driver door mechanism is working electronically atm.
Ok, checked the wiring diagram again and driver door electric lock goes through the relay as well so it must be there, yay!
