lj73 transfer oil leak ...help
Hellas
Hello . My lj73 pass the oil from the gear box to the transfer case so there is a lot of oil leak all over the t.case..
Does anyone know how can I take the t.c. out to change the oil seals
The Australian fix is to run a pipe from both fill bolts from the gearbox and transfer case. This keeps the oil level equel in both until the owner gets around to replaceing the seal. The transfer has a breather like the diffs so make sure this is venting OK and the gearbox breaths through the bell housing somewhere if these are blocked it may cause oil leaks. The way I checked mine was to pump compressed air into the fill plugs and Listen for air coming from the breather. If this fails time for a rebuild. :)
What he said
I've thought doing it to ...
I bought the oil seals and I try change them
Ineed help to find out how to
