Lj72 short body Wheels size
Vietnam
I've seen on the internet a lot of LJ72 fitted with 15” steel rims to go 33” tires without spacer and don’t touched front lower ball joint. Can anyone who is going with the 15" rims working properly can tell me your rims specs? Please..!!!
Xin Chao It depends a lot on your suspension. I think the factory rim was a 15x7 inch. I had 15x 8 inch but mine had leaf suspension but I think they would be ok if your suspension hasnt sagged Did you want to use 33x9.5 or 10.5?
I saw a LJ72 in Vung Tau a few weeks back, they seem to be importing a few. Do you know where they come from?
My car was lifted 2” suspension by OME and I try to put 33-10.5-R15 but I wanna know what offset- is right for it? Should I put a spacer for it?
It will depend on what offset the rims are. If they have 3.5 inches of offset, they should be ok(I think)
Can I see a picture of a lj72.
Here my LJ72 😻
1943843
1943844
1943845
Very nice LJ72 you have there! On my LJ79 I run 15"x10" -32 offset wheels wrapped in 33"x12.5" mud tyres and on a 2.5" Dobinsons suspension lift. I still had to use 5mm spacers up front to get a little clearance to the steering arm ball joint. Without the spacer it rubs against the ball joint's rubber bellow. I think with an 8" wheel -32 offset would clear the ball joint, but for a 10" ideally it would be around -40.
Can you tell me your wheels specs?
Do you use spacer?
I don’t remember the specs on my wheels but I did not use spacers. I had slight rubbing and tight clearance on the caliper but I grind it a little to make it fit. I did end up buying spacers but have not intalled yet.
