I am a relative newcomer to this site, and in reading the various opinions about the Prado and the 2L engine, it seems that there are essentially two different vehicles. The first is a reasonably serviceable vehicle that keeps up to the traffic, is reasonably responsive to throttle pressure, can pull a small trailer, and gets reasonable fuel economy. The second can barely do 80 km/hr with a headwind, smokes and overheats. I am writing this because I have had both of these in the same vehicle, and my experience might be useful to somebody. I had the Prado for about a year and drove it about 10,000 km before I noticed air bubbles in the radiator while getting the transmission flushed. It unloaded a bunch of antifreeze on the floor and started to warm up. It was shut off before it got really hot. It only seemed to do that at an idle, but I can only theorize why. The official diagnosis was (Quelle Surprise!) A cracked head. The head was replaced with a 3L head and I picked it up from the shop and headed down the highway on a 330 km trip. They said “it runs good”, but cautioned I should get the fuel pump calibrated because it smokes. By the time I got to my destination I prepared a chart of how it was different from before the head change. It is as follows: Exhaust Before — Smoke during heavy load at low engine speed. Cleared up as soon as engine was up to speed. After — Smokes all the time at practically any engine load, sometimes very heavy on highway. Throttle response Before — Very light pedal pressure was required to get moving at a reasonable rate. After — More than half throttle is required to move. Maximum speed on level Highway Before — 140 km/hr After — 100 km/hr sometimes downshifts on apparently level road Highway hill climb Before — Maintain 110 km/hr on any hill on Highway #2 After — As slow as 80 km/hr on Highway #2. Engine temperature Before — Middle of scale at all times after warm up. After — Top end of scale at highway speed, Mid scale at city speed. Oil Pressure Before — Mid scale all the time on the road. (with 15-40 Oil) After — On Hwy hill climbs, drops to middle of lower third of scale. (With 5-30 Oil) (the Head guys changed the oil) Fuel consumption (Hwy) Before — 11.0 l/100 km (25.6 mpg) After — 20 l/100 km (14.1 mpg) Engine Noise Before — Nothing unusual After — New, minor clatter at higher than idle speeds, not a typical diesel clatter Stalling Before — Don’t recall it ever happening After — Stalled at gas station in Red Deer, twice. Three times on Deerfoot trail in heavy traffic. All this before I got to my destination in Calgary after leaving the shop. Stalled again next morning after a cold start. After a few days I drove back to the shop using the temp gauge as a guide. Any speed over 90 km/hr would cause the engine to start to heat up. I prepared the list above and delivered it to the shop. They asked if I could leave it with them and I did so. There were a number of theories about what might be wrong and the shop people said they checked them all out. One of the technicians told me that the electronic fuel pump on that model was “problematic”. 1. Compression was within specs on all cylinders. 2. Valve and fuel pump timing were correct. 3. The cover cap was removed and a sticky valve was found. It went back to the shop who installed the valves in the new head. Supposedly they freed it. 4. The injectors were sent to a diesel shop for service. Two needed repairs and were checked to be within specs and re-installed. The shop called me and said it had to be the injector pump, but they could not do that. They suggested the pump was “overfueling” (whatever that means). I picked it up to take it to the diesel injector service shop. With all the "repairs" it ran worse than ever. Getting moving at all was very slow. It might take 10-15 seconds to get the first 15 yards. It still smoked and the clatter noise was greater. The injector service people said they had a dynamometer and could test it under load in the shop. They were booked up for two weeks and I would have to wait. I told them that would be OK. I could not drive it anyway. Due to holidays and a shortage of staff, it took a month to learn that my injector pump timing was out relative to the valves and crankshaft. They re-installed the belt and it runs OK. Total elapsed time for this saga was three months. It should have been done in a week. On the first subsequent highway, with a load of wind resistance on the roof, it smoked quite a bit, and the farther I went the less it smoked. After a couple of hundred kilometers, it was clean. Fuel consumption is back to normal and I can keep up to the traffic.
