little bolt under accelerator?
What is the function of that bolt under the accelerator? what will happen if i lower it all the way? right now it's about 3/4 out.
thanks!
The bolt is there to so you don't damage/bend anything when your smashing down on the pedal trying to impress the ladies. ;)
I removed mine and bent my pedal down alittle to make more room. Its a lot more comfortable driving long distance now.
i dont know but you should remove it and let us know what happens when YOU do it now:flipoff2:
you want the pedal to have a stop before the linkage at the carb stops. That way you do not wear out the carb linkage or stress the butterfly.
You would adjust that bolt so that you get maximum movement at the carb. Then raise the bolt so that the force is taken into the floor not the carb...
make sense?
It wasn't openin the Ark that did this....he touched the bolt...
