Lift Parts
Bakersfield, Ca
I thinking about buying a lift kit, my question is what are the extra parts that the kits dont give you? And are there any threads that tell the step by step of putting one on. What is the real difference of the med and heavy lift, is it just the amount of weight you can put on them or will it make the ride really rough with the heavy?
hit the technical links and use the search button... tons and tons of info regarding everything you've mentioned. since the questions you asked were fairly broad because there is so many types of lifts, thats where i'd start *tech links*
Not another lift thread :cheers:
On a serous note my BDS came with plane-jane shackles.....Gonna get anti-inversions next month....
Meet my spending limit this month buying a clutch slave and master....
Your BDS came with shackles? mine didn't... Just used the stock ones. The rear spring packs were too short, though, and I had to get some anti-inversions so they wouldn't invert when the truck was lowered off of the lift. Got OME's, and I think they're actually 10mm lift!! :flipoff2: beefy compared to stock
