Lexus V8 Wiring service for Engine Swaps
LexusV8 Engines
Supporting Vendor
Website
www.lexusv8.com
LEXUS V8 ENGINES LLC
WIRING SERVICE for ENGINE SWAPS.
Starting at $450
1UZ and 3UZ- manual and automatic.
You simply send us you engine harness and ECU. We will bypass your immobilizer at a small extra charge on your ecu if required.
We will wire up your engine harness so that you have 3 wires to connect to get your engine to run. We build a fusebox onto your engine harness so it becomes a stand alone system on an OEM Management.
We will also wire in your alternator oil light, rev counter and temp gauge, aswell as OBD2 where applicable.
Where OBD1 is relevant, we wire it into your fusebox so that you can read flash codes..
We also stock the majority of the connectors and we give technical help and advice.
We located in Florida, USA.
www.lexusv8.com
sales@lextreme.net
Tim 305 619 5355
Sally 770 722 2345
Please note we are now called Lexus V8 engines and not Lextreme.
Wiring of 1UZ and 3UZ lexus engines....
