For lots of years I was a pickup truck guy, loved having the convenience of a truck bed. Then I fell in love with Land Cruisers, and found I used a truck bed like once a month or so. My solution was the land cruiser plus a trailer.
So, a handful of years ago, I sold my last truck and started using a 4x6' trailer with my 200 to fill this gap. It was a cheap used thing with a steel frame and incandescent lights. It got the job done.
Over time, I got sick of chasing lighting problems every time I used the trailer - bad ground, blown bulb, mouse chewed wired, corrosion. So, I went out and bought a high quality aluminum trailer with LED lights all around - life was good. Everything worked, the lights were dead reliable. No messing around when I used it.
That worked for years. But, recently I had a passenger side marker light on the fender go out. This lens is a red rear, yellow front side marker whose receptacle is riveted to the fender. The light is the style with a removable lens module that contains the LEDs, and a fixed receptacle. It has both a positive and a negative terminal (like bullet connectors) moulded in - so it is not grounded through the trailer frame like some lights.
All of the other lights (including the drivers side marker) still worked correctly, as bright as intended.
So, I bought replacement lenses that matched the original equipment part number:
Optronics MCL61ARBP Amber/Red LED Fender Light
I plugged the replacement in, and it worked but very dimly.
I cleaned the trailer side receptacle with Deoxit, worked it in and out with a spare bullet connector, and then some very fine sandpaper, and made sure the female pin receptacles were making a tight connection.
I checked for voltage and got 12.67 volts.
I plugged the new unit in and unfortunately I still got the same result - the passenger side marker light was on but the bulbs were very dim.
I swapped the light modules driver and passenger side - and the both the new and the old light modules were appropriately bright when they were on the driver side and very dim when on the passenger side. This leads me to believe the issue is not the replacement lens/light assembly, but the trailer side of the system (at least on the passenger side marker circuit).
I am admittedly not very electrically inclined, but with other LEDs, I understand that adding a resistor dims them. So I'm wondering if is it possible that I have some sort of electrical resistance that has built up in this circuit that is causing the dimness? Maybe a corroded wire, pin or connector? Or a poor electrical connection that is making contact, but not solidly?
Thanks in advance for any guidance you can provide.
www.amazon.com
