So I replaced my winch cable with synthetic winch line (amsteel blue 5/8ths from Steve at Southeast overland). I used the winch 3 or 4 times then it started leaking red hydraulic fluid.
I thought that was strange since it is not a PTO. I took it to the local Toyota dealer, at first they said it would be covered under warranty, but they needed to order the parts and would call me when they arrived. (It's a 2013 76 series with factory winch and only about 4500km on the odo at the time).
I thought that was strange since they couldn't tell me why it was leaking and I could tell they hadn't removed the bumper to actually look at it.
About two weeks later I still hadn't heard from the dealer so I called them back and they said Toyota had rejected the claim because I had "modified" the winch by replacing the steel cable with "normal" rope. I sent a long email with the specs of the rope and lots of links showing that it is not normal rope and is in fact meant for winching. I also complained that they had not really looked at the winch and couldn't even tell me what was wrong with it. They agreed to look at it again and reconsider.
I left it with them for another day, wait two more weeks and they call me back saying that my claim is rejected because of the modification. They still can't give me any cause/effect reasoning as to how this could have caused the leak, or even tell me exactly where the leak is coming from.
Today I removed the winch. I can tell that they did not remove the bumper and there is no way they could see the winch with the bumper still attached. I removed the rope and will bring the winch one last time to try and get them to show me where it is leaking from and how the rope could have led to that leaking.
I think the fluid may be coming from the little rubber hose under the motor visible in one of the photos below. You can also see from the photos how much fluid has leaked on my driveway. I'm pretty sure my previous winches have all had grease inside, not red fluid.
I hope they come around because I think the winch appears to be well built (except for the leak ) it seems very heavy duty compared to most other winches I've seen and owned.
Is there a way to appeal something like this directly to Toyota, or am I stuck trying to deal with the local dealer?
