LC in Homewood
Nashville
Me and the family were driving thru homewood today an saw a white collectors edition broken down in front of a store(don't remember the name). Anyone know the deal on it? Front end is broken..
Really? Was the knuckle bolts out or come loose? Causing the trunion bearings to pop off the bottom? That's the only thing I can think of that would allow you to see the front axle was broken. Or was it the front bumper?
Lets all go start pulling parts off it, like they do on rigs on the interstate.
Meet you at 11!
Yeah, if the tie rod and relay were hanging then that's the bottom knuckle bolts that also holds the trunion bearin in place. That's the only thing I've ever seen work loose in an otherwise stock rig. Those nuts should be checked by EVERYONE with an 80....
Yep - at Robe mans. You can see the steering arm lying on the ground and the wheel is falling off.
In all seriousness, it is a nice looking white collectors edition. I bet if you could track down the owner they would sell it for cheap and it should be an easy fix. No telling what Robe Mans is going to charge for it.
Unless it is there because robe mans just did the front axle and didn't torque those nuts properly.
Could be. might be a pssied former custmer returm! ;-)I will call them today to see what they want for it.
Just called them. A customer towed it in to them. Didn't say if they did the work or not...
