Knuckle Rebuild Kits - Gears - Steering (1 Viewer)
Status
Not open for further replies.
cruiseroutfit
Supporting Vendor
Moderator
Utah
Website
cruiseroutfitters.com
Now on sale at Cruiser Outfitters....
Drum Axles $90.00
Disc Axles $87.00
FJ80 $111.00
Tie Rod End Kits
FJ40 (69'-83') $69.50
FJ55 (69'-79') $66.50
FJ60/62 $89.50
Gears
FJ80 Rev Cut Front (4.88/5.29) $187.00
40/55/60/80 (4.56/4.88/5.29) $162.00
More Here...
http://www.cruiseroutfitters.com/specials.html
Thanks :D
For those that called regarding the steering kits...just got more of the kits back in stock.. thanks!
Do the 5.29's require any modification to be installed into a 1978 FJ40's diffs?
[quote author=ScottFJ40 link=board=8;threadid=9217;start=msg91946#msg91946 date=1074488026]
[/quote]
Yes, in the rear only, unless you have a FF. You will have to notch the ring gear for the cross pin to fit in. I have done this on several, you might consider 4.88's as they require much less grinding...
Thanks
-Kurt
Status
