I have not yet seen this truck, but a friend has a 1999 cruiser that is super finicky to start, need to wiggle key and pull it out before it will turn..Key was recut by Toyota and no improvement?
Rob
Rob
The dealer should be able to do it from the VIN #.How do you get a key cut to factory specs? Every time I get a key cut they just follow the contour of the key I give them. That would get you two sticky keys instead of one. I have the same issue but it's sporadic, most times no problem, once in a while it takes fiddling. It's the same for all the other "worn" copies I've made.
