my keyless entry stop working; checked out the key battery is good. does any one know where is the receiver ECU locate at? or what can cause this problem?
Yes...reprogram...I can't access the program mode. Transponder is working fine. Key entry is ok. Or lock/unlock from out side is fine too. It's won't arm/disarm or set the anti-theft system.Not sure of ecu location, but have you tried reprogramming the key? Remote Transponder Key Programming
The ECU for the receiver is directly under the steering wheel in my 98. Anyones Keyless Entry Suck?
Also, i wasn't able to figure out which was the antenna lead (my guess is that its internal) but I didn't try too hard either.
