Kaon Shelf (1 Viewer)
I just took a look and one side of the bracket sits inside and the other outside. I didn't notice it during install. No issues so far. If you go off road often, maybe use some blue loctite.
On another note, I installed my shelf at the highest setting, i'm going to try the lowest setting to allow for more room. Hopefully it doesn't interfere with the rear view mirror view.
Thanks for confirming. It’s something minor that I just wanted to make sure.
I was thinking about adding felt tape around the metal to metal contact points. But i haven’t heard any rattles driving it around today.
I put mine on the lowest setting (upper most hole). With my seating and mirror position, I can still see the full glass without the shelf blocking anything
@ltsr @Littlehouse
Did both of your brackets sit on the outside of the shelf?
I installed mine this evening and one one side of the bracket sits on the outside of the shelf and the other side is on the inside of the shelf.
The Kaon install video has them sitting on the outside. Pictures are from their install video.
Edit: For those curious, I put the bolt head inside where the threads are facing towards the window. I figure it’ll be a cleaner look and less issues for anything to snag on the longer threaded side.
I just looked and both of mine are on the inside of the shelf, and I have the threads facing the window.
They already have the table, love mine, curious what this will be?!
Source: Comment section posted by Kaon (from Acrad's Link)
Ooooooo, I wonder if it'll work with the table?
i'm keen on ordering their table but see they also have that 'attic' shelf which looks great. Anyone using this?
Yep, I have both, they are great and I would definitely buy again.
Put on order. I debated this forever but its such a wasted space, helped getting the 10% discount. The 168.00 AUS shipping hurts. Still less expensive than the JW offroad one.
