My mind is made up & I just ordered the OME FJ60 4" deluxe kit with shackle reversal
. I can't wait to get it here & get started. Anyone else have this kit? Looks pretty awesome.
Haha, you should make a auto reply to anyone posting about OME springs. thats like the 10th time Ive seen you saying that here.The "A" Spring goes on the left rear of the vehicle.
Not always, I have the "A" spring on both sides, level as can be.![]()
What size tires are you going to run? I was thinking about 32" tires once I have the lift kit. I have seen 33" and they look like they may rub a bit. Any input?
I had a shackle reversal kit on my FJ40 before the spring over and adding gussets and the like is a good idea. You'll hit the spring mounts frequently if you do a lot of off-roading as they are champion rock finders. I thought it rode and drove well with the SR and had no problems other than hitting stuff with the mounts. I assume you are welding on the mounts? I would not just bolt them on and call it good.
come on cruiserdrew, what you fail to point out is that the front hanger sits exactly as low as the stock shackle but doesn't invert when you drag it over a rock. More springs get destroyed from inverted shackles than anyone could count
