Just bought a lj78, looking for more information.
Chilliwack, BC, Canada
Just wondering what everyone had local part numbers for these 70 series Prados...
I guess I'm mainly looking for part numbers, online manuals, crossover parts from other cruisers that came here in North America....
I have been researching a ton, but wondering what else everyone else had. I'd love to do up a PDF file in a few months with everything I've found. If this is a repeat post, could you kindly post up a link to the original.
Thanks for everyone's help in advance... I love this forum!
GTSSportCoupe on 'MUD is your go to guy for all things Prado.
Prado is not the most accurate term because it only applies to LJ78 sold in Japan. The Australian SWB models were called Bundeeras and in South America they were called Landcruiser II
Wont be too many parts that crossover with North American models,possibly some electrical components .
Most of the parts will be similar to their big brother 7* series and Hilux Surfs.
On the diesel forum ,there is a parts number sticky at the top that where you might find something.
We probably need another sticky on the 70 forum for body and transmission part numbers.
Congrats on your purchase Jarrat! Prados are pretty wicked little trucks when properly taken care of. They are really tough and solid as long as you don't get the engine too hot. As I'm sure you've read, the head's on these are susceptible to localized boiling which can lead to cracking. It is preventable though. I've had my truck for a few years and just love it; had no problems at all with it.
Postoy has posted most of the stuff I was going to post, so I won't repeat any of that.
Just a few things to note on these trucks. Watch for the injection pump leaking diesel. Eventually it will need a seal kit as the old ones dry up and start leaking. I recommend scrapping the emissions systems. I highly recommend going to Evans waterless coolant which will prevent the head from cracking even if over heated. I also recommend upgrading the undersized radiator cooling fan. Finally, if you want more power, exhaust and an intercooler makes heaps of difference, and it's easy to turn up the fuel/boost and make a good 50% more power reliably. This will also improve economy believe it or not.
Tell us more about your truck. Manual or Auto? Rear locker? SX5, EX5? Year? Are you in BC?
Cheers!
Nick
Also, another great resource is ToyoDIY: http://www.toyodiy.com/parts/q.html You can use it to look up Toyota part numbers, and then do a reverse search and match the number to North American models.
Whats the problem with your u-joints? Have you greased them recently? I looked up the U-joints quickly on Toyodiy and I'm pretty certain they cross over to the first and second gen 4-runner and the 80 series land cruisers. You should double check before buying parts tho.
I'm in Chilliwack BC, Canada. The truck is a EX5, Auto, no goodies, 1990.....
Other than the Evans, and bigger fan... and maybe a good flush... what else can I do to upgrade the cooling... my truck seems to have a newer rad in the truck (not factory original), maybe it was put in a couple years back?
I had some drive shaft vibration getting on the freeway right after purchasing it, seemed to fad away after 10 min. I do want to pull them apart, check it out for a piece of mind.
On my last three suzukis I've always ditched the clutch fan and swapped in an electric always with awesome results. Have you heard of anyone doing this to the 2.4 head problem engines? I might give it a try but with a two speed two temp sensor setup and a buzzer alarm for the higher temp setting.
Also same with the EGT system, just bought a digital readout one on ebay with an alarm that can be preset to a temp.
I think I'm going to get a alarm system with a turbo timer as I live up on a mountain side and temps do climb right before I hit my driveway.
The reason for all the alarms and such is incase my wife is driving it as a reminder something is wrong.
Hey Jarrat, sounds like that truck is in good hands and you've got some good ideas.
To make the cooling as good as possible:
- make sure the whole system is clean and well maintained.
- Install a transmission cooler to help dump the heat. The transmission when out of lock-up generates a huge amount of heat which it dumps into the coolant. When you power the truck up a bit, you will be able to maintain lock up more, which will help keep every thing cool.
- The other thing I did that made a huge difference was put thicker silicone fluid into the viscous clutch. Made a huge difference. You can also shift the internals to make the clutch engage earlier.
- Also, I run an 82C thermostat, not the factory 88C one. This gives a lot of extra head room.
- Make sure the system is well bled and you are not loosing coolant anywhere.
- Never run the truck over half on the factory temp gauge. In my experience, this is where the localized boiling in the head starts; especially when under load and with high EGTs.
If you ditch the clutch fan and go electric, let us know how it works out. I'm curious.
Yeah, definitely get some gauges. Pyrometer, Boost, Coolant Temp, Trans Temp...
Turbo timer is a great idea if you run your truck hard right before you would shut it off. I don't have one, but I've taught my wife to not shut the motor off until the EGT's drop below 400F. After a hard run this can be a minute or two. The other thing that can happen if shutting the motor off after a hard run, is the coolant will boil in the head around the hot spots, and this will lead to a cracked head eventually (because it is no longer circulating when the engine shuts off). So never shut the engine off when it is hot. Always let it cool down to about 1/3 on the factory gauge before shutting off.
Good luck. Nice to have more Prado owners showing up. These trucks are really great machines, and would be way more expensive/popular if it were not for the engine heat challenges. So if you fix the heat problem, you've got a good rig for a good price.
GTSSportCoupe - Jarrat is a good friend of mine who has been wanting a Prado for quite some time and finally has one! I am also interested to know how the electric fan works out. I have had the opposite luck with my v8 swapped jimmy... that thing over heated no matter how big of an electric fan I ran.
Jarrat - When you are ready let me know when its time to yank out your EGR and Throttle plate. Nick and I have both had great success with this MOD. Id like to do it after you have an EGT gauge hooked, I never had mine on before so Id be interested to see the difference in EGT's.
What weight of oil is everyone putting in their rides?
I buy 20 litre pails of Rotella 15W40 when it goes on sale at Canadian Tire. I run it all year round and it seems fine for our mild climate here on the coast.
Just found the engine manuals again. I used these recently when I replaced the head on my truck. These manuals cover our engine perfectly except for the EFI system. All the mechanical is dead on though. These manuals are hard to find, and much better than the other manuals commonly available (like the old rocker version of the 2L-T manual).
RM520E (Main for 2L, 3L & 5L engines)
http://forum.h4k.no/download/file.php?id=14135&sid=f426b91359e5825fb43df98b70107dfa
RM582E (Supplement for 2L, 2L-T, 3L and 5L engines)
http://forum.h4k.no/download/file.php?id=14134&sid=f426b91359e5825fb43df98b70107dfa
