- Location
- United States
Had this posted in Classifieds, maybe best here...
Pile Of Isuzu Diesel Conversion parts. Mainly 4BD1T/2T
No Blocks, No Heads Left.
Injectors, Injector Lines, Injection Pumps, Front Covers, Valve Covers, Valves, Valve Springs, Keepers, Rockers, Rocker Shafts, Housings, Side Covers, Filter Adapters, Manifolds, Acoustic Covers, Banjo Bolts, Misc. Hardware, Feed Lines, Push Rods, Timing Gears, Mounts, Crank Bolts, Front Harmonic Pullies, Etc, Etc, ask me and I might have it after some digging.
4BD2T Injection Pump $650 USD + the ride (Good runner, catastrophic rad leak (road debris - fist size hole), overheated and dropped a valve seat)
4BD2T Injection Pump $650 USD + the ride (Motor was sitting for long time in a field, never ran it)
4BD2T Injection Pump $650 USD + the ride (Motor smoked, never investigated reason, pulled and swapped out quick)
(NO OTHER PARTS FOR 4HE1T) 4HE1T Injection Pump - $800 USD + the ride (Good runner, turbo seals failed, sucked crankcase oil, ran away and threw a rod)
4BD1T DI Injectors - Ran well, probably worth a rebuild, or at least nozzles, $300.00 a set + the ride.
4BD2T IDI injectors - Not sure on condition, sold as rebuildable cores, $150.00 a set + the ride.
Lots more, ask.
Lots more, ask.
