Introduction and question
Raleigh, NC
[FONT=&quot]Hello,
I am the latest owner of a 77' fj40. Bought it from the father of a IH8MUD member in Minn. It is a reasonable nice truck, needs some work bit runs well. The PO did the following on the truck;
2F engine - Replaced with another Cruiser engine after not fully engaging the distributor (which drives the oil pump) on the original engine. Replacement engine has approximately 70k original miles- desmogged, non-US vacuum advance distributor, header, custom 2.5" exhaust.
New clutch, pressure plate, throw-out bearing, pilot bearing, and resurfaced flywheel.
SM465 transmission: rebuilt w/ new brgs and synchros, plate style adapter (3/4" thick plate adapting to Toyota t-case). 3spd transfer case (came behind FJ40s with a 3spd transmission: this has a lower low range than the original 4spd case): completely rebuilt
ARB air lockers front and rear factory 4.11 ring and pinion gears with ARB air compressor with wiring harness. All new bearings and seals in the front and rear differentials and axles.
Front Birfield Eliminator Kit: replaces the birfield joints with custom axle
shafts and Dana 44 U-joints, also replaces hubs and lockouts with Dana 60 (1 ton) components
33x12.50x15 BFG Mud Terrains on white steel 15x8 wheels. 2.5" Skyjacker softride suspension system with shocks
1.5" over stock length shackles, heavy duty with reinforced cross-bar.
Power steering using Astro van PS box mounted inside of the frame rail out of the way. GM style "teardrop" Power Steering Pump on custom brackets
'72 replacement tub, including the firewall, from an Arizona truck, cleaned and painted the frame. Grey bedliner on the interior of the tub. Custom rock sliders with reinforced rocker panels. Drop-down aluminum tailgate with internal storage area. Wet Okele seat covers over factory seats. Full 8-pt family custom rollcage.
After driving it a few days, I noticed a strong oil smell and saw that a leak had developed from either the transmission or transfer case. I cannot tell exactly due to the custom slider. I can do some work on some cars but I need help with this.
I'm looking for a shop or mechanic recommendations in the Raleigh area.
Thanks in advance for your help.[/FONT]
Sorry for the delay
Attached are a couple of photos for my FJ. Like most FJ's, it is in a process of improving and restoring.
Looks like you have a 40 in great shape.
Thanks for the replys
Any recomendations on local shops. I've got several small leaks, oil and gear oil and would like them checked out.
see previous page
Hello, I just joined/logged in and have some of the same questions. I did notice a post on the previous page with some info entitled: local shops in your area 11/9/06 . Maybe that will help. Steve
P.Barber, IMHO most 40s are in a process of restoratiion, not improvement. Hard to improve on something that good.
I personally don't know any mechanics in Raleigh. Hopefully someone will post up from there.
