I was looking over the FSM wiring diagrams over the weekend. Specifically the two pages of wiring devoted to the connections into the ECU. I spent at least a couple of hrs at it but was not able to make heads or tails of it.
For instance. The ECU shows wires coming into it and labels those connections. Specifically I was trying to find the wires into the ECU for the O2 sensors. One was labeled E2 (I actually forget the exact number but it is not important). To me that would mean I should look for plug E and wire pin 2 on the plug. But there were only 4 plugs coming into the ECU and they were labeled A,B,C,D. That means that there was no plug E. Whats going on here. The diagram actually showed plugs on up to G going into the ECU. Can anyone explain what the E,F, and G were?
Another case showed me that my belief that those were plug indicators was totally wrong. Plug D had pins up to #22 but the wiring diagram showed a wire into D25. Huh? (I said)
