- Joined
- Sep 17, 2012
- Threads
- 1
- Messages
- 2
I have a 1988 Toyota 4x4 pickup. I have been troubleshooting an ongoing starter problem. My truck will start fine for two or three weeks with no problems. Then suddenly Ill turn the key over and the starter does nothing. I have replaced every component in the system. The key cylinder, clutch start switch, brand new die hard battery and even the starter. I repaired a loose wire previously that i thought fixed the problem, but did not. I removed a wire harness to the key cylinder and had it tested for continuity, all checks good. When the problem occurs i check the volts at the battery and the power is fine. Right now since the starter is under warranty im going to replace it. I'm thinking the solenoid is not working properly. If this does not fix it, i may have to put the truck in the shop. I am hoping someone in here may have had some problem and can help.
