I have been having an intermittent issue that started two days ago. Door locks have always worked fine. Now all of a sudden, most of the time either the key fob or door switch opens only the drivers door with all others failing to open. I can hear the relay click behind the dash but nothing opens. But here is where it gets strange. Every once in a while they work great. All of them. I can hit the switch 10 times and on the eleventh it works great. And sometimes once that happens it works great for ten or so times and then stops working again. I'm thinking it can only be relays or a bad electrical connection. All the searching I have done says replace the actuator motors but that makes zero sense here, to me at least. How hard is it to access and find the relays? Any suggestions?
