Had my 3FE rebuilt and finally installed today. When I started it up it is popping under the valve cover and running really rough. Won't idle and will run around 2K rpm. A neighbor mechanic used some starting fluid around the intake and the rpm's came up.
My question is any suggestions before I tear the intake back off and replace new gaskets?
I have re-torqued the manifolds, adjusted the valves again and set the timing three times.
