i want to build a utility trailer (about 6'x8' with a 3500lb axle). does it need to be certified or anything? i'm sure different states/provinces vary (i live in B.C). some pics of your own trailer would be great.
I know in PA (which is not where I live) it is extremely difficult, but not impossible, to get one approved for road use after being home built. FWIW, if I did it again, I would find some old trailer with a valid registration and simply "re-work" it no matter how extensive that may be . Since you are asking about B.C. , your best bet would be to check into the local laws up that way first.
I built a trailer for someone in BC once. You just needed to fill out some paperwork at the insurance company and then get a set of tags. Took a couple hours to do with all the running.
i live in bc and my boat trailer is registered as home built although I didn't build it. I have heard of people building their own trailers. I would call your local autoplan for instructions.
When I bought my M416, I did not get a title from the military, just a bill of sale. In the state where I lived at the time, that was not enough to register a trailer. Since I was doing some pretty heavy modifications, I decided to register it as a home-made. All I needed was a list of the parts used and two pictures of it that showed the rear lights and the front safety chains, and I was all set.
I paid $35 and the new VIN plate came in the mail a few weeks after that.
I just went through this in California. The trailer had to be 'verified' by the DMV guy, and a VIN Number assigned and attached to the frame. Took about an hour - mostly waiting in line. They issued a trailer plate valid for 5 years.
In WI the trailers need to be inspected by the Highway patrol, this involves scheduling a time. Once inspection is passed they will issue you a vin # then the DMV will sell you a plate.
Also In WI under 3500#'s does not need a registration.
In Colorado, you simply state the size and weight of the trailer, sign some statement that it is strong enough for whatever you want to use it for, they give you a metallic foil sticker with a VIN, a set of plates, and stickers for the plates. I was surprised how simple it was. Then I was scared how simple it was; I went way way way overkill when building my little 4 x 8 utility trailer but not everyone will do it right, there are a lot of rickity looking rigs around here.
