Instrument cluster red light question...
Denver CO
Is the red exclamation point associated with the brakes? Mine has been lighting up sporadically. Any and all information appreciated.
If it is your brakes, check your brake fluid reservoir cap (either the cap goes bad or it just needs fluid). It has a sensor built into it that does go out over time and will trigger the warning light. It is the same light that comes on when you activate the e-brake handle.
