Installing AHC Rear Accumulators in front
Hi all,
I was offered to install rear accumulators in the front since the front ones are out of stock. I know that they have a higher pressure in them. Do you think it will change the ride quality? I am thinking to install an ARB or Slee bumper in the future, do you think it will handle the weight better?
Thanks,
Tzur
I'd go for it. I've got a spare set of lowish mile rears (from an 06, the fronts are installed and replaced my originals) that I will install on the front just to see how it works. Couple of things come to mind. The drivers side won't have a lot of clearance between the larger globe body and the height accumulator connector so you might need to fiddle around there a bit. Also you'll need to experiment to get the optimum damping by varying your TB loading - I think you'll need to back off the TBs to increase the neutral pressure, hence force slightly more fluid into the gas/fluid chambers. Kind of opposite effect to when your neutral pressure is to low (too much torsion bar force) and the ride becomes under damped and springy, for want of a better word. And, as you add weight and the globes age you can easily rebalance and adjust torsion bar force to weight to pressure for optimum damping.
Interested to hear how this turns out...
