Has anyone installed a temperature gauge to an A442F transmission to monitor fluid temps? If so, can you provide some insight into the process and recommend a gauge? Thanks.
Not a ton of help as I haven't done the work yet. Waiting until my next trans fluid drain/fill. Just gathered parts... went with a new tapped fitting from Radd Cruiser dude then just an Autometer gauge with short sweep sender.Has anyone installed a temperature gauge to an A442F transmission to monitor fluid temps? If so, can you provide some insight into the process and recommend a gauge? Thanks.
Thanks, Guy. Would the gauge come with the temp sensor or would I need to buy a sensor separately? So I'll need the fitting, the temp sensor, and the gauge?Not a ton of help as I haven't done the work yet. Waiting until my next trans fluid drain/fill. Just gathered parts... went with a new tapped fitting from Radd Cruiser dude then just an Autometer gauge with short sweep sender.
Transmission Cooler Fitting - HDJ81 A442F 90407-20006 - https://radd-cruisers.shoplightspeed.com/transmission-cooler-line-fitting-90407-20006.html
Some good threads maybe in the 80 series section on the process.
B
Probably depends on what gauges you go with. In my case it was sold separate and I stayed with AutoMeter so it matched a previous owner installed gauge.Thanks, Guy. Would the gauge come with the temp sensor or would I need to buy a sensor separately? So I'll need the fitting, the temp sensor, and the gauge?
John
Thanks for the info and feedback Stuart!I'd also advise getting the converter lock up kit as well
