Installation of Automatic Differential Locker
Did you have to remove the Crown Wheel, to get the Cross Shaft out?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Total voters
Jonathan_Ferguson
★ is in the wrong locale
Glen Waverley, Victoria, Australia
Website
jonathan-ferguson.au
richmondgear.com/0002pdfs/1000708B.pdf Page 8
Disassembly of the Differential Case
1. Remove the ring gear if it interferes with the removal of
the pinion shaft. It may need to be tapped off with a brass
mallet. Mark it so that it can be re-installed in the same
otational orientation as when removed. Note: if the pinion
shaft can be slid out past the ring gear teeth, the ring gear
does not need to be removed.
I also asked on forums.overlander.com.au.
