Ok fellas. I've never worked on a 100 series before, but I'm going for it.
I'm in the midst of my starter replacement. I have checked out a few videos and read some threads. I don't know a lot of automotive terminology and I'm going on visuals. I have disconnected a bunch of stuff, but definitely not all that needs to be disconnected in order to get to the starter.
So I need some help and guidance. I will provide pics accompanied with my question.
Here's what I've done so far. I have labeled hoses, bolts, and their placements. Pics.
First of all I read on a thread that there is a hose that is a gas line. It read that it wouldn't leak when disconnected, but to be careful. Not sure where that line is. I haven't disconnected these two lines. They are on the DS near the back of the manifold/firewall.
Question #1.
Any of these two lines the one that's connected with the gas?
Not sure what these guys are called. The connections are located on the PS near the front of the manifold.
The easiest way to disconnect hoses that have welded themselves onto the pipe fittings is to grab a pair of pliers and twist them off to "un-weld" them. Then you should be able to pull them off by hand.
