After much procrastination, I finally got around to organising my in cab winch control switch. It started life as an antenna switch, but with a bit of help from NLXTACY's how to threads I have relabled it as the pics show. The antenna symbol sorta works for the winch I think, and they do look much better in the flesh than in the pics. The top button arms/disarms the switch and the bottom two are in and out.
My winch remote is the older three wire version so I have wired a common ground, in and out by tapping into the wiring in the solenoid box. This way I can still use the remote if I need/want to. I will see how this goes with a view to possibly rewiring it through a pair of relays so I can't hit both buttons at once, but I can't see that being a huge issue. BTW there is also a kill switch in the main winch feed wire.
Sorry about the shoddy photos, as you can see I had already started to relable the switch when I thought I'd better get a picture of it. Unfortunately, macro photography is not my strong point!
