Improve Handling?
Chicago
My rig: 2002 LX470, Slee Lift Kit 1.5" - Tundra 4.7L Engine (really torquey)
I fully understand that this car is a brick on wheels. My car has decent level of power and I would like to know if anything will improve body roll/handling? Like torsion bars, x-brace, sway bars, etc?
I am nearly at my ultimate setup and would like to take it just a bit further.
Thanks for any help!
Start simple before you throw parts at it. Tire pressure and type will likely yield more performance than all the items you linked above.
I like my Michelin Mud and Snow tires and tire pressure is good. I just thought there might be some suspension components that could greatly improve body roll. It's not horrendous but at higher speeds much more noticeable.
Start with fresh sway bar end bushings. Most are toast.
You'll have to check specs to see what diameter bar you already have. Or a pair of calipers... <- in regards to the links you posted, not the end link bushings, they are independent of asb diameter....
