So yesterday, I was fixing a small leak coming from the evaporator box. No big deal, just took to cover off, cleaned out small amount of debris, replace gasket, and reassmebled. Then itried to start it. First try, cranked fine, but didnt start after ~2 seconds of cranking, with no indication of any firirng. Second try, it started. Took at short drive then back into the garage. 2 hours later tried to start and cranks fine but no firing. I noticed the VSC TRAC and VSC OFF lights were on. Also noticed the theft deterent light flashing. found a thread that mentioned the EFI fuse conections, so I checked and cleaned those contacts. Checked battery in key which was fine. Not sure what to check next. Any help would be appreciated.
Thanks
Thanks
