It might change through the years but just played with different years 98 and 99 to see what should have to be changed over to get it to start and key less entry to work with out reprogram.
The column has a transponder module that goes to the RF coil around key ignition, And the main engine computer behind the glove box, Both have to be changed to start the truck. Also tumblers then glove box, front doors, and hatch for a complete conversion. In theory. You could remove the coil around the key and put it under the dash with the correct key wrap d together, then use what ever key hardware you have. Use it for remote start without extra pieces and then only need metal keys.
