im getting a 3rd gen 4runner
so im getting this 974rnner and im wondering if my 15x10.5x35 km2's will fit. i know ill have to do alittle bit of trim work but sonoran steel the place were this lift is from says they should fit. my question is will the wheel fit on the hub or will it rub on the caliper it is a 4x4 sr5 any help will be apreciated. thanks im posting a pix
what about if i use a spacer like from trail gear or marlin???????
It might work with a big enough spacer, but on mine stock steel 15" wheels are not even close to fitting. I've since upgraded to Tundra brakes and the calipers are even wider. Probably need something like a 3/4" spacer. And that may mess with your geometry. Of course your best bet is sell the tires and buy some for 16 or 17" rims.
Unless you've got 7" spacers, you won't be able to fit a 15" wheel (if it came with the bigger brake package).
well the the 35's 15 inchers did fit on the truck but they hit the caliper and it will not let the tire turn going to get 1-1/2" spacers tomorrow hope it works??????
didnt have to trim anything but the fenders and put some 1 1/2 spacers and its going good in the process of doing a sas.
