I probably won’t use the rack for anything other than a Thule box so my main consideration is that install is as easy as possible for the SkycampDLX. I’ll have to remove each use as my garage clearance is low.
Yes you are delusional. What makes it awkward is the size and the fact you are lifting it over/around the vehicle. For our mini the easiest way I’ve found is to attach it to the Yakima round bars (78”) on the ground then lift it by the bars since they are wider than the truck.my thought was…..it’s less than my military press and it’ll be divided by two. Am I delusional? Sounds like I am.
I
