I have a 12/89 FJ62 with a custom exhaust system that's about 2 years old. It uses the stock downpipes and then a cobbled together y-pipe and then new stuff behind that.
I blew an exhaust gasket a week or so ago (the gasket between the
exhaust manifold and the down pipe). I decided to replace both for
good measure and seemingly fairly easily installed new OEM gaskets just now. Apparently I don't know my own strength, as I cracked the downpipe right next to the flange as I was tightening the nuts, so now I have a brand new, nice big exhaust leak right there.
Question: I'm going to try fix this myself. Does anyone know if
this is a pretty standard size flange/downpipe that I can find at
Napa or order from someplace like Summit? My exhaust is all welded together, so I'd have to drop the whole thing to measure it, which I will do if necessary. If I can't get a part, I'll just weld the crap out of this one to patch it.
Having an exhaust leak right next to the engine is kind of
interesting. You can really hear what is going on in there - I can
tell when the ECU changes something and can hear very clearly when
there is a little stumble or misfire...
Job!
