Ignition Coil Lead Wire??
Dallas
Hey yall, wondering if this could be my issue after some troubleshooting but really have no idea...
Flashing CEL and rough engine, code said cylinder 6 so swapped coil pack with 4. Code moved to 4 as expected.
Replaced the bad coil in 4 with new OEM. Still code in 4.
Swapped #1 coil with new OEM from #4 expecting code to move to #1. Code did not move, still at 4 with rough engine.
Could I have damaged the coil lead wire on #4 when removing or am I in some deep #$%^ here? Emphasis on the $ part....
The wire is my only other idea, doesn't seem like that would kill a spark plug
I wish I could delete this because I'm an idiot. I swapped that coil three times before I realized the plug was jammed. So...check your connections! thanks mud
