I think it's time for an engine rebuild?
Plano, TX
1973 FJ40 - One owner - In line 6 - three speed.
approximately 111K
sounds like and feels like its running loose.
What would be an average $ to have this job out. sourced?
Tom in Dallas
Isn't that an F engine? SOR quit doing F's a long time ago - it looks like they don't even do the 2F any more.
SBC is likely cheaper. I wanted to do a corvette 283 engine.
Every now and then one of those lifted diesel p/u’s with the extra large exhaust tailpipe passes me and the sound it makes reminds me of the sound I make when I’ve eaten something my stomach disagrees with, kind of “loose” sounding 🙈😂
approximately 111K
Tom in Dallas
A lot more in big D than here in the land of NASCAR...
My 2F has been sounding loose for about 3 decades; tune and adjust it every two or three years and drive it until it drops.
To summarize above:
1) check compression dry n wet..
2) adjust valves
3) check compression dry n wet
And then go from there (Toyota 6 bottom end is just getting broken in at 100,000 mi.)
P.S. If you think there is a specific problematic sound, you can use a long screwdriver pressed to your ear and the location to listen or just buy a cheap mechanics stethoscope (you’ll get to hear all sorts of internal noises) to identify where it is actually coming from. Hopefully And likely just valves.
There is a really great mechanic up there who may be able to get you sorted, Chris @ToyotaTechnical
I vote for a valve adjustment as well. I’ll be up there in a few weeks and could perhaps walk you through it. PM me if you want.
Thanks. What is an estimated $$ I;l reach out to Ghris at toyota
i might be using a wrong email.
Can you forward my information?
txxx_xxxxx.com
2xx-xxx-xxxx
Tom - Plano
Tom,
Take your private information off.
Scammers abound.
Direct Message me if you’d like.
Thanks for the kind words, @RevISK
Tom, I am happy to come take a look. I am in north Dallas. @TX73FJ40
