i know its not a yot.. but 1994 wrangler
For sale: 1994 Jeep Wrangler Trail Vehicle
Up for sale is my 1994 Jeep Wrangler. Red in color, good overall body condition, clean clear and green title in my name. Odometer shows 195k miles, not original motor, and odometer no longer works due to transfer case swap.
The bad
This is not a daily drivable vehicle, while I have put many (several thousand) street miles on this since completed, it has only seen 70 miles an hour 2 times since completion, its not meant for that kind of use. While still being street legal, this is a purpose built off road vehicle.
The transfer case needs to be fixed or replaced. I may do so if I have time, but until this is done it is non-mobile.
To move this it will need to be towed.
Needs one wheel, currently has one with non-matching back spacing.
Tires: 2 have 50 percent, 2 have 30 percent tread left. All have been grooved professionally.
New clutch slave, and master assembly included, needs to be installed (external slave)
Rear main seal leaks, 2 piece, just needs to be installed
The good
16 inches of total lift, 5.13 gears, and locked front and rear axles. Front and rear aftermarket bumpers, onboard air, roll cage, harnesses, etc, etc, etc. Below is a compiled list of installed parts.
List of installed parts
From C.O.R.E
Pressure plate, pilot bushing, center force stage two clutch, throw out bearing, master cylinder, resurface flywheel, jack, jack mount, jack handle isolator, tow strap, weld on axle pads, heim joints, jam nuts, heim seals, offset bushings, steering box brace, ax-15 to Dana 300 adapter, Rubicon express rear springs, twin stick shifters, seal, drive shafts, 14 bolt, and Dana 44 gears and install kits, blue torch fab brackets, twin stick shift boot, shock stem eliminators, stuan tire deflators
From Bob Howard
Crank position sensor bolts, clutch master/ slave mopar assembly
Four Wheel Parts
Bikini top and install kit
American Automatic Transmissions
Rebuild transmission in 2003
American Engine installations
Remanufactured engine installed in 2001
Supplee 4wd enterprises
More and teraflex shackles
Shaker built Off-road
Knuckles, studs, spacers, high steer arms, ball joints
Salvage Yards
Dana 300, alternator
Napa
Fittings, tow shackles, bolts
Blumenthal’s
Driveshaft parts
Mid West Hose
Steel braided brake lines
Auto Zone
U-joints, u-joint straps
Tolly Fabrications
Roll cage, raised solid motor mounts, traction bar, skit plate, suspend seats in cage,k hydraulic assist steering
O’reilly auto parts
Wheel studs, lug nuts, spindle bearings, crank position sensor, differential bearings, optima red top battery, battery terminals, brake calipers, brake wheel cylinder, brake shoes, brake pads, brake hardware kits, brake adjuster kits, all axle seals, all wheel bearings, u-joints, headlight switch, u joint straps, headlights, switches, fuse block, wiper blades, every oil change, axle breathers, York onboard air ac clutch, idler pulley, serpentine belt, water pump, fuel pump, strainer, plugs, coil, cap, rotor, oil pan gasket, rancho rs5000 shocks, pinion seals, and Hurst t handle.
Parts purchased from individuals, or already installed
Pro comp front springs, front Dana 44 axle, rear corporate 14 bolt axle, 38.5 tsl sx tires, wheels, rear tire carrier bumper (built in air tank), front ARB front winch bumper, kc pillar lights, underbody lights, cargo lights, bucket seats, RCI 5 point harnesses, Cargo holder, k and N filter, onboard air compressor with 2 built in tanks and front and rear chucks/ pressure switch. Front lock right locker; warn lockout hubs, front windshield tinted, and 14 bolt 4.10 and lower ratio carrier.
Reason for sale:
I am currently in college, and do not have time to work on it, or enjoy it. I do not have a truck or trailer to transport this vehicle, so my ability to use it is limited to the availability of others tow rigs.
Price
Looking for 7500, or trade for truck, trailer, car, motorcycle, dirt bike, quad. Partial or full trades accepted.
Contact
Drew Harris
Jeepjackazz@yahoo.com
Pictures
price is negoitable! i need a daily driver bad!!! located in okmulgee ok
had a pm about the last pic with the broken shaft. that shaft was built to drive it to c.o.r.e to have new shafts made, and was never intended for long term use. since the pic, blumenthals has built 2 new shafts, and all yokes on this are new.
