HZJ79L transfer-case used with R151F?
Hello Gents,
Trying to identify the transfer-case used on the 2010-now HZJ79 with the R151F transmission, as I would like to have a dual t-case setup for a mining truck project.
I found a spec sheet that lists a BF1B t-case, but I am not familiar with that model and have been unable to find any further details on it.
Attached is a photo and following is what I know thus far on transmission and t-case;
- transfer-case input shaft is 23 spline
- 1st = 4.313, 2nd = 2.330, 3rd = 1.436, 4th 1.000, 5th = 0.838, R = 4.220, t-case high = 1.000, t-case low = 2.295
Any details on t-case model, mating pattern, and input shaft details for making mod kit would be greatly appreciated.
Cheers,
Paul
A few more images of the mating surface
From the images below, does this look similar to other transfer-cases that any of you have run across? For reference, the distance between the dowel pins is approximately 6 inches.
Cheers,
Paul
