Hzj 76 - manual transmission & Differential fluid
Kuwait
Hour important is it to change the manual transmission & Differential fluid? Should I change the fluid in my car's Differential? How many times I need to change it every year?
Year model 2008 . 60,000 Kilo
I need your expert adives.
Thanks in Advance
Do you have the owners manual? It will specify which fluids to change and when. I just hit 100 000km so I did diffs, gearbox, transfer, engine/filter, power steering, brake/clutch, radiator, fuel filter and air filter.
Thanks in Advance
Its supposed to be changed every 25000 or 30000 klms or every year. The klms varies from country to country
It's always been every 100,000 km for my vehicles.
Certainly it is specified in your manual.
Thank you .
I seriously doubt that is true. I dont have the FSM for the R151 gearbox but I am sure it is 25000klms for the gearbox,t/case and diffs .
The only things that have a 100000klm service interval is the injector pump,the injectors and timing belt.
But what do I care,its not my gearbox.
Change once per year to be safe, and anytime you go through really deep water.
If you are not in deep water, 60k Km is a safe interval.
