Hi everyone, on the Lodge here in Zambia we have a HZJ 75 with the 1HZ (1HZ stands for 1 Happy Zambian by the way
) annnd the front brakes keep sticking on.
The pedal is very hard and has very little travel, the top 2" or so locks the brakes. The brakes stick whether you use them or they slowly brake harder and harder as you drive.
To 'solve' it so far we have been cracking the bleed nipple on the caliper, this releases the pressure and you can drive on a bit more.
I've cleaned the caliper pistons, all fine, measured the brake booser pushrod clearance, checked the check valve and cleaned the master cylinder ports. I've tried pumping the pedal with the engine off to exhaust the vacuum, then standing on the pedal and starting the engine to check the booster is working....the pedal does drop but slowly, there's no obvious 'drop'.
Anything else you suggest I check??
I think I'm going to blow the brake lines through with the compressor next to make sure they're not blocked but apart from that I'm running short on ideas!!
Any help would be appreciated!!
Thanks
Joe
Thanks
Joe
